跳转到主内容
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
426 个问题 查看全部
Network connection issue all of the sudden
The network connection all of the sudden quit. I rebooted my wifi router and tablet several times but to no avail. I event use WPS setup and it says the tablet is connected but when I go to internet it is not connected. When I tap on the network in wifi settings to connect it will say it is connected then dropout. What is can I do to fix the issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Tablet is connected. But it is stuck on connection check. When I back out it says connected and excellent signal strength.. I hit next and it says this can take a while. Has been stuck there all night. How do I get past this step? The skip button is there but isn't clickable.
HELP
完成的
添加一条评论
3个答案
已选择的解决方案
I am back because I fixed the network issue. Maybe this will help others.
I finally convinced my wife for me to factory reset the tablet. After doing so the tablet is back to normal and network connection issue was fixed. I have to reinstall all the apps which was no big deal.
Thank you Robert Osburn for the suggestions.
这个答案有帮助吗?
得分 2
1条评论:
Can't find my paperwork,how to factory reset modelw122sc24
完成的
添加一条评论
Thank you for replying. I have tried all that you suggested except factory reset. My wife would not let me. She wants to keep all the games in it. I have a reason to believe that one of those games sabotaged the tablet. When you kept playing them and not purchase tokens.
I said that because I have to factory reset my M8C TV box twice. This last time it became a brick. When I tried hard reset with reboot SD card, it would not boot anymore. It was stuck with S802 logo on the TV scree, After trying several attempts the LED eventually turned off, the sign on logo went out and the TV screen went blank.
On to shopping for a new TV box and tablet. Bummer, lesson learned .
这个答案有帮助吗?
得分 0
添加一条评论
Having similar issue however, what if you are dealing with a server that is in another country? Example:
I use an online slot game that is based in Cyprus a cheesy nothing island about 5000 miles away and often because the signal has to transfer via satellite which is how most internet long distance works via WiFI my RCA tablet either locks up or I lose connection and often lose my credits on the game because of it. I use a cheesy WIFI booster app but, often that shuts off and loses connection. Tablets in general may be nice and handy to use but, let's face it I think it has a lot to do with the built in antenna on them and if you have too many walls from the router and the distance of where the servers are has a lot to do why WiFi cuts out.
Always consider whatever we look at online not every page or especially gaming apps will work that great because most may be long distance. Each server locally may have to communicate to another server long distance depending on the origin of the website. All signals have to go out into space and back to router to device we are using.
These servers have to transmit billions upon billions of packets of data every second so that we consumers can complain about why we lose signals or data drops and most have to communicate via satellite. Hence, it is why they call it wireless!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lnfortun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 18
总计 8,032
