touch screen freezing repeatedly
Hello everyone!
Actually I've searched several places into this community, but couldn't find an answer that fits what I suppose is the problem.
What is happening is the constant and persistent freezing on the screen of my Iphone. When it happens the devise blocks and the only way to resume working on it is the light off of screen and start that all over and even some times doesn't work properly and I have to do againi the previous steps.
I've already tried several processes including reset the phone into its factory configuration, but didn't work.
Is there anybody able to inform any possible cause and possible step to fix it?
Thanks you all in advance for the attention and cooperation.
Rgds
Marco
17条评论
If you've done a Factory reset then it pretty much has to be hardware. Replacing the touch screen (about $100 in USA) may take care of it.
由 rokin154 完成的
Gents, in addition to my above question one more thing I've remembred about this tiouch screen t is about probably some ghosts doing something on it.
Actually the screen starts application withou a single touch sometimes looking like a ghost is doing something invisibly. Looks like a joke, but this is happening very often. So this is also a possibility of changing the display and solve these issues or should I check something else??
Thanks + Rgds
@bellarosa Marco
由 Marco Bella Rosa 完成的
I had exactly the same issue. That was why I came here through Google search. Since I didn't get a solution from the Web. I used my own way. The problem is solved. At lease, a few days now. My way is: slam the phone on your palm once or twice. Your palm can cushion the force. It won't damage the phone. But it will fix the issue.
由 bin64603 完成的
I'm also having this problem and like you I slam the phone on my palm BUT this only works sometimes. I thought I'd solved the problem for good a few weeks ago but the problem as returned. Any ideas?
由 maire 完成的
Holy $@$*. I love you bin64603!!!!!! it worked!!
由 halliemaria 完成的
显示更多的12条评论
