跳转到主内容
The camera has a 2.7” LCD screen, a 12 megapixel Four Thirds sized sensor, and a built - in flash. Dimmensions are 115 x 72 x 42mm.
17 个问题 查看全部
The small internal date time battery data what type is it, where?
The internal data battery does not hold the date and time when replacing the main battery on my Olympus E-PL1. What type of battery is it? and where is it located?
I hope you can help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
that sounds write changing a small capacitor inside without a circuit diagram and component list could be dodgy! I am capable with a soldering iron. Olympus service won't tell and want to charge more than the camera is worth. If anybody knows the value of the capacitor ( farads) it will quite small. I should be able to get the component and fix it Thanks rokin154@crowbot.
完成的
They call these components "super caps". It's possible you could locate it on the board. Likely the farad rating would be kind of high with the voltage being low (5V, 12V). Best of luck.
完成的
添加一条评论
1个答案
已选择的解决方案
It's likely that the camera uses a capacitor to keep the clock and memory up while changing the main battery. If the cap fails (as they sometime do) then you'll see this problem. If that's the case the only solution is having it repaired.
I found this during a search. https://www.dpreview.com/forums/thread/3...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robbie Cwik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 53
总计 1,846
