I can't move apps to memory card
I have the ZTE Majesty z799vl I need help with moving apps to SD card
You can move apps data to SD card by going to the settings/app then click on the app you want to move and in the app settings screen that pops up you will see a move to SD card button go ahead and push move to SD card.
It will let you move downloaded apps to the SD card if its gray then you can't move that app
这个答案有帮助吗?
How do you do that for the ZTE Majesty Pro (Z798BL)?
I have only one app it is Verizon message plus and the rest were already installed and everyone who has this model phone has the same problem with storage space even with the 32sd card.where can we get help?
i'm having the same problem just put in a 16 gb sd card and none of my app can save data to it. i have 2gb used already but when i select the show sd card nothing. Has this been solved?
Hi @home_1469 ,
Check whether the SD card has been mounted by going to Settings > Storage and see if it is listed as storage.
If it hasn’t been mounted here’s a link that shows how to mount a SD card in Android.
Be aware that when mounting that you have to reformat the SD Card so any data already on it will be erased.
Also note that when the SD card is available for storage that not all apps can be moved to the SD card. The move to SD card option on the app will be greyed out as the developer of the app has decided not set it to enable.
这个答案有帮助吗?
过去的24小时: 1
过去的7天: 5
过去的30天: 27
总计 7,009
I dont even get that option...on any app
由 John 完成的
I don't even See the option to move the app, and my phone keeps telling me I don't have any space left, yet I got a 32gb memory card in it
由 Robert 完成的
