跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
My brand new screen is not working properly
I recently ordered an iPhone 5s case, I have replaced iPhone 5s's before and i never had this problem. I plugged in everything and charged and turned on the phone, and the display is still unreadable, any suggestions? I don't want this forty dollars to go to waste
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Hi, the screen is damaged try another that will fix the issue.
这个答案有帮助吗?
得分 0
添加一条评论
Your LCS ribbon (plug) isn't clipped on correctly to the board you need to push down till it clips on then slowly and carefully close the screen.
This is a bit tricky to do because when you lift to put the screw on top everyone makes the mistake of lifting the screen to give you clearance to put the tinny screw on the top metal shield and by lifting you unclipped the LCD plug which the metal holds in place and not getting good connection.
这个答案有帮助吗?
得分 0
添加一条评论
This is the connection that gets lose when putting in the top metal screen just push on it till you hear it click in place it has to click in place I have make the mistake of putting it on and seems like its connected put never hear it click so I found out it clicks when it sits correctly
这个答案有帮助吗?
得分 0
添加一条评论
Your new LCD is surely dead or poor quality. Contact the seller and get a new one from him.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack Swanson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 56
