跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3720 个问题 查看全部
Can I change white lcd to a black one on iPhone 5s?
I recently changed my white iphone 5s lcd screen to a black and and now the whole left side of my screen is black, it works but it is black
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Perhaps your battery has moved under or get bigger due to watter dommage or repair. So it push the back of the screen. If not, screen is probably faulty or connector/chip is damaged.
完成的
添加一条评论
3个回答
已选择的解决方案
The LCD/Front Glass is mounted on a plastic frame. Take a look at this teardown for reference. It is for the iPhone 6S but generally applies to all iPhone screens.
What that means is that the color of the front frame and glass are totally irrelevant electrically speaking. The phone does not know the difference between a Black or White replacement screen. You can install whatever you please.
As for the specific display issue you show in the picture, this is caused by a defective replacement screen.
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
这个答案有帮助吗?
得分 2
评论:
I just added a photo
完成的
Hello Sadik. I have edited my answer in light of the picture you have posted. This is caused by a defective replacement screen.
完成的
添加一条评论
Hi, it looks like your screen is damaged try another screen.
这个答案有帮助吗?
得分 1
添加一条评论
There is no difference on the function of different color, disassemble your iPhone then reinstall again, also check the connectors before installing it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sadik Elahi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 21
总计 1,205
