跳转到主内容
加入维修社区 - 创建账户
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
Screen flickers when plugged into AC power, no boot.
Whenever I plug in the AC Adapter into my customers iPad, the screen flickers once every 3 seconds or so. I've tried doing a hard reset with it and nothing. I've opened her up and see no noticeable damage whatsoever. I've tried another adapter known good and the same problem happens. Any troubleshooting i'm missing? I still have the ipad open currently. I wonder if reseating the dock port will fix something.. Any help would be mucho appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
Did you ever spill water on it
完成的
添加一条评论
4个答案
已选择的解决方案
Thank you for your help. Unfortunately i've ruled this as something I unfortunately won't be able to cost effectively fix for the customer
这个答案有帮助吗?
得分 0
3条评论:
I have the same problem I have tryed and got the iPad to power up by using a higher amp like 5v 2.4amp cube or same power out put with usb connection,that’s when for me it went to the blue apple iTunes logo and can reset with no luck comes back to iTunes logo.it will turn right off if unplugged. Computer port will Flicker because only 500ma for power coming through USB connecting on standard so not enough amps to power it up.thing of using and independent powered data hub next. If I can keep power 2amps on 5 volts going in the iPad it would work to reset os.i think its the battery. When set into recovery mode computer will recognize but when trying to re-install OS it shut power to USB which canceled Install because power to iPad stops and iPad shuts off.now no power and a1600 error comes up it’s a usb problem wich means when the computer tried to disconnect then reconnect it lost power to Apple iPad.
iTunes will connect and reconnect multiple times before install that’s where I’m at now I think it’s the battery.these battery’s are only really good for like 3 to 5 Year’s decreasing from like two years on.if iPad has been put away for long periods Of time the battery will decrease little by little because of microchip safety with battery.
完成的
Same problem..but inuped the power supply. To a apple power supply now no blink its stuck on the apple. What next.
完成的
Did you happen to find out whats the problem?
完成的
添加一条评论
Try replacing the LCD,
这个答案有帮助吗?
得分 0
5条评论:
I would however it seems to be the dock connector possibly. I don't have an option to turn it off and on. It automatically turns on once AC power is plugged into it. Holding the power button down does nothing with the ipad. However, if I hold the power button AND home button, the flickers stop until i release one or both of the buttons.
完成的
yes! that's what mine is doing.....
完成的
Same here, mine too!
完成的
@timspc i have that exact problem,buying a new casing as mine is in bad condition and dock connector
完成的
I think I have the same issue. I captured an image in a dark room showing how the backlight flashes every few seconds when the iPad is off but plugged into a power adapter.
https://imgur.com/a/uh61rlz
完成的
添加一条评论
Tim, my bad take a look at the power volume flex at the sleep wake sensor it could be damaged.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
needs new battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim Rauls 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 80
总计 19,340
