跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
Installing a HD in optical drive bay
I have an old iMac 20" (EMC 2133)
I'd be interested in removing the optical drive and replacing it with a small SSD to run OSX on. I know this can be done with on a Mini, but I found no info on whether or not this can be done at all on my iMac model.
Any info would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Replace it just like you would a normal hard drive. Here's how: iMac Intel 20吋“EMC 2133和2210 硬盘更换
UPDATE
Sorry, I missed that. Here's what to use: iMac & Mac mini Dual Drive Enclosure
iMac & Mac mini Dual Drive Enclosure图片
产品
$19.99
这个答案有帮助吗?
得分 3
2条评论:
Good to see you back. +
完成的
Sure - I understand that the procedure to get to the ODD and HDD are similar.
Nevertheless, I am going to need a caddy of sorts to house the SSD where the SuperDrive used to be, or not? What sort of caddy might I need?
And, is the connection SATA or PATA for the ODD of a Mac A1224?
Thanks
完成的
添加一条评论
It won't work. The early 2008 iMac used an ATA connector for the Superdrive... not a SATA one. Sorry...
这个答案有帮助吗?
得分 2
添加一条评论
I just took my 2007 20” iMac apart to do this with a caddy similar to the one recommended above and this won’t work because the connector, as noted by Lawson above, is different.
(optical drive is below, ssd caddy above).
这个答案有帮助吗?
得分 1
1条评论:
Yes, the top one is SATA. The bottom one is ATA 100, a much slower interface, which is what pre-2009 iMacs use in the dvd slot.
完成的
添加一条评论
Hello Mayer, I just wanted to make sure that the "12.7 mm SATA Optical Bay SATA Hard Drive Enclosure"
works on the Early 2008 iMac. It only lists MacMinis as being compatible.
If it does, I would like to use it to install a SSD.
Thanks in advance.
这个答案有帮助吗?
得分 0
2条评论:
Just to be sure (none of the adapters are listed for iMac) I would contact iFixit directly and ask them. Here's where to do it: http://www.ifixit.com/Info/contact
完成的
I just sent them a message, thanks.
完成的
添加一条评论
Did you ever get an answer if this would work?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Valerio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 6,012
