跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Guides and support for various TV brands and styles.
5239 个问题 查看全部
Why is LCD TV backlight flashing?
Samsung LN-T4065F LCD TV 40"
The TV is 10 years old and has 5700 viewing hours.
The backlight is flashing on and off at a rate of about 3 times/sec. You can see a video of it here: https://www.dropbox.com/s/q7ngflkituz774...
This used to happen periodically then go away overnight. Now it's not going away.
How can I debug if this is an inverter problem? I have a multi-meter. Or should I just buy the $17 inverter and hope for the best?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
The backlight inverter is damaged. Needs to be replaced. Requires soldering. You could send the board off to a board repair shop in your area or mail in
这个答案有帮助吗?
得分 2
评论:
What kind of soldering? Videos I've seen show that replacing the whole board is basically plugs/wires. https://www.youtube.com/watch?v=Kwhih4U1...
完成的
You could do that. Would be much easier
完成的
Did some multi-meter tests on the inverter. Couldn't find any problem. I'm just going to spend the $17 for the new inverter board and see if it fixes it.
完成的
Ok. Let us know if you need anything!
完成的
New inverter fixed it!
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 8
过去的30天: 40
总计 2,486
