跳转到主内容
The Twentieth Anniversary Macintosh was a limited-edition personal computer produced by Apple Computer, Inc., in 1997 in celebration of the 20th anniversary of the company
6 个问题 查看全部
Screen replacement on a TAM
Greetings.
Is there a guide available to replace the screen on a TAM?
Thank you for any information.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Surprisingly the one guide we have will get you there!
Here is the guide: Twentieth Anniversary Mac Teardown. Follow it thought to Step9 to get the front off which has the LCD screen mounted.
Just be careful you get the correct replacement display, you can't substitute.
这个答案有帮助吗?
得分 3
7条评论:
Just to confirm, please: ALL steps through step 9 are required? (Thank you for your response.)
完成的
We just don't have a proper guide, yes I'm sure a few of the steps could be bypassed. As you go thru the task how about creating a guide ;-}
完成的
Hang on to this machine, it's one of the few older ones that retain real collector value. I think there were only 10 or 12,000 of them made. I only know of one in my town.
完成的
Agreed! Its a collectable.
完成的
Thanks, guys. Yes, I intend to keep it. It is iconic ... in its own rather eccentric way. (I'll try to complete a guide; however, I think I would end up plagiarizing most of Dan’s guide. If I’m successful, I will be sure to note proper attribution.)
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 554
