跳转到主内容
修复你的物品
维修的权力
商店
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
15 个问题 查看全部
White hose near back wheel -- What is it?
Hello,
I have a 2008 Yamaha Vino 125 and I noticed recently that a white / clear hose on the left side of the back tire is disconnected and hanging down. It seems like the attachment that allows it to fit in the hole on the scooter is missing as well, so I need to know what the hose is that I'm looking at to be able to replace. I can upload a picture if no one knows off the top of their head. I think it might be the crankcase breather hose but I'm not entirely sure. What damage could be done without that hose connected?
Thanks!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
3个回答
已选择的解决方案
Here are images from a previous answer that you may find useful
The hose could be from the evaporative fuel canister Number 12 and 13 in the second pic . Hope this helps
这个答案有帮助吗?
得分 2
评论:
hey @oldturkey03 hope you don't mind I gleaned a couple of photos from one of your old answers
完成的
@jimfixer Mike is out with Harvey for a while. I'm sure he won't mind with help on the questions at all, and I know I could sure use the HELP ;-)
完成的
@mayer has anyone heard from Mike since the storm hit? Pray hes safe I know he lives in Harveys path . He'll probably be pretty busy at the hospital
完成的
I have not heard from Mike in three days, but I'm sure he is covered up at the hospital.
完成的
添加一条评论
I suspect it is a battery overflow hose but not sure. Posting a photo might help confirm it.
这个答案有帮助吗?
得分 0
评论:
I just added two pictures. Thanks!
完成的
would be a battery overflow. I have a Yamaha 1100 and the battery on those are gelled.
完成的
添加一条评论
https://www.yamahapartshouse.com/oempart...
The 2007 and the 2008 might be close to the same model. I think that that is the fuel overflow or spillage tube.
best method is to follow it if you can. Might try this trick. put a flashlight in the tube, turn off the lights and see of you can see where the hose reflection is. I've done that a few times to chase down a few hoses on my stuff.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
john.intemann 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 11
总计 317
