Where is the pixel wifi antenna?
my pixel fell onto ground and since then the wifi becomes very weak. wifi can be found but not connected unless i put the phone on the wifi router. maybe some problems are within the wifi antenna. i tear the pixel down but cannot find the wifi antenna. can anyone show me the position? really need help
5条评论
I am also facing same problem. Can you please tell me how did you fix your connectivity issue?
由 Marmik Shrestha 完成的
@tosepe could you fix the problem? I have the exact same issue after i dropped it. It would be very helpful if you share what happened
由 Seenat 完成的
How was the problem fixed? Was anyone able to solve it?
由 amadib 完成的
i have also the same issue with my pixel
由 SaLlar KhAn 完成的
My speeds on my pixle 3 XL is 15mb with data and Wi-Fi compare it to my Samsung note 4 and my note 4 is getting more than double of the speed my pixel 3 is supposed to get
由 Callum Bhayani 完成的
