跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
425 个问题 查看全部
Front left power window does not work,.
2002 honda accord automatic V6 four door .
Front left power window does not work,20A fuse is ok.What to check next? Thanks Ivo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Looks like the window was just stuck.Thanks anyways
Ivo
完成的
添加一条评论
1个答案
最有帮助的答案
> does not work
Does it try to run? Whirr? Klunk? Or totally silent?
There is a 20A fuse (#15) for the windows, but also a 7.5A fuse #13 for the "multiplex" brain. I'd think a dead multiplex would cause many troubles, but check it anyway.
The switches, relays, and multiplex brain are all-in-one. The factory diagnostic is many pages of tedious tests, and the end result is replace-the-unit.
So check the motor. See attached image from the manual.
If you can hot-wire the into working, but not via the switches, replace the whole door-module. A good auto salvage operation should have these.
This is from the 4cyl 2002 Accord. The V-6 model is different in many ways. You'd think they'd use the same window-motor?
这个答案有帮助吗?
得分 2
1条评论:
How can I download the manual?
完成的
添加一条评论
添加你的答案
tumai 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 13,377
