跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
778 个问题 查看全部
The PlayStation 3 hard disk's file system is corrupted
The PlayStation 3 hard disk's file system is corrupted and it doesn't restore when i press 'ok'; it keeps repeating the same message. what do i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
5条评论
Hold The Power Button 2 times Hold The Power Button For 3 seconds if its red do it 1 more time then it will give you instructions to set Up Safe Mode Press option 4 It Will reset the system then i think its gonna save your games
Thats All i know
完成的
i have the same issue, but when i press the off button 3 times for more than 3 secs each, still the safe mode doesn't come up and the same error message about a corrupted file system appears again
完成的
It work for a slight moment and then quit working and said corruption again after I restarted it again and again
完成的
i am downloading saves online as i had to wipe out the whole data due to reasons and it shows corrupted what to do
完成的
添加一条评论
3个答案
已选择的解决方案
1. Make sure the red light on your power button is RED.
2. Place your finger on the power button, and hold it down. It will turn green, then eventually go red. Give or take 10 seconds.
3. Release your finger. This lets the system know it's fixing to enter Safe Mode.
4. Then place your finger back on the power button, and hold it down.
5. It will beep once then twice, and THEN take your finger off the power button.
6.You should have a pop up on your screen that reads: 'Connect your controller to your USB cord, and press the PS button (The PS button is the one that has the PS logo on the controller). Do that with your controller,
7. then you'll have a list of Safe Mode options on your screen. Choose the one that reads, 'Restore your PS3 System.' On mine, it was option number 5. Could be different on each Gigabyte console.
8.Anyway...Hopefully some of you will see this, and save yourself time and money. Hope I helped you all out. =)
这个答案有帮助吗?
得分 22
32条评论:
after i choose number 5 does it remove all of my files??
完成的
Thanks it worked .. but it erased all my achivments :S :(
btw thanks alot (Y) u really helped me man :)
完成的
How long does it take to restore
完成的
how fast can you do this or does it matter in how fast can you restore the file system on Ps3 it doesn't say in how fast you can do this please explain to me how
完成的
This works! Yes it deletes all the files but that’s a small price to pay to fix my PS3!! Thank you!!!’
完成的
显示更多的27条评论
添加一条评论
This does not work with off-brand controllers :(
这个答案有帮助吗?
得分 3
6条评论:
Actually, you don't use the joystick for Safe Mode selection. Use the up and down on the D-Pad (looks like a cross!) to move the selection light. Hope this helps!
- Amy Cymore, Sony Inc.
完成的
Thank you so very much for this information! I tried safe mode multiple times with different types of controllers and was about to give up, without realizing that the joysticks didn't work but D-Pad (which I never use) did. Within minutes I was able to restore my PS3 from a brick to a working system. THANK YOU!!!
完成的
I used an iPlay controller just fine
完成的
I only have an aftermarket controller it does not let you connect to the ps3 at all while it’s it. Safe mode. The screen stays on “connect the controller using a USB cable, and then press the PS button”
完成的
Please I followed the steps and am able to restored it, but there is no option as you talking about that we should choose option 5, there is no display like that so please help me
完成的
显示更多的1条评论
添加一条评论
so im not sure that will work all the time it might be a simple fix of haveing it refurnished that is what im gonna do but let me know how that works
这个答案有帮助吗?
得分 0
2条评论:
Thanks man!, it worked out you are the BEST❤
Love from Nigeria ??
完成的
Do it erase the games one has on the console.
It worked but all my games were whipped off!
完成的
添加一条评论
添加你的答案
vatoloco 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 112
过去 30 天: 432
总计 92,995
