跳转到主内容
How can I unlock my iPod
My little sister was play with it and lock it. I forgot my combination and can't unlock it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
ive down loaded some music and turning it back on its showing the padlock feature and i cant unlock it ...how do i unlock it
完成的
It may also be called _volumelocked
完成的
添加一条评论
3个答案
已选择的解决方案
Here is a link to Apples procedure for setting and removing the lock. Please note you will lose all your data. Good luck.
http://support.apple.com/kb/ht1350
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
rj713 is of course absolutely right. There is a also another way to reset it without losing the data from your ipod :
first plug in the ipod, go to my computer, click on the ipod drive. Go to tools > folder options then click view. Click show hidden files,
Go to ipod_control, then go to device. There should be a file named "_locked" delete that. Now unplug the ipod and you should be ready to go
Good luck
这个答案有帮助吗?
得分 4
3条评论:
didn't work so don't konw
完成的
it did not work
完成的
This Helped Alot Thank You
完成的
添加一条评论
Go to Ipod folder in computer make sure hidden files are displayed
go to
-ipod_control
--Device
---_locked
don't delete it, just change it to un_locked
worked for me many times, just don't know how to full remove code or change it without restoring ipod
这个答案有帮助吗?
得分 1
2条评论:
Telling her how to show the hidden files would greatly improve your answer.
完成的
This actually worked for me! In explorer go "View > Hidden Items" and uncheck it. Then go to the folder "IPod_Control" and do as described above.
完成的
添加一条评论
添加你的答案
melissa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 38
总计 14,115
