跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
57 个问题 查看全部
Can I change the battery of my OnePlus 3 to a OnePlus 3T battery?
Hello All
The battery of my OnePlus 3 is giving me issues these days. I was wondering if I could replace the current battery with the 3400mah OnePlus 3T battery.
OnePlus 3 comes with a 3000mah battery whereas OnePlus 3T comes with a 3400mah battery. On the other hand, the device tree of both the devices is almost the same and people are even able to apply OnePlus 3T body to a OnePlus 3
Please let me know if such activity is possible and how should I proceed with it
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
5个回答
最有帮助的答案
I try this and it doesn't work. Seem like Oneplus has patched it and it shows not compatible when I trying to boot up with a bigger battery
这个答案有帮助吗?
得分 3
添加一条评论
First source:
According to the official Oneplus team, you can't swap the batteries back and forth.
Second Source:
According to Jerryrigeverything: https://youtu.be/n1sg2y8OuJs?t=140
In his video, he says that although you could technically swap the batteries back and forth, the software on the Oneplus 3 and the Oneplus 3t differ. This makes it so that even if you put a Oneplus 3t battery into a Oneplus 3, you wouldn't get the 400mah increase due to software charging restrictions to prevent overcharging.
In my opinion, I wouldn't bother swapping batteries because you probably won't see any difference in battery life, and the Oneplus 3 software wasn't designed to use the Oneplus 3t battery.
这个答案有帮助吗?
得分 0
评论:
I got one question: Isn't the software validating the charge of the battery by the voltage? With it doing that it will SAY 3000mAh and THINK you have 3000mAh but the voltage will drop not that fast and you will have a benefit anyway. + even if you cant use the extra 400 mAh wouldnt it be better for the battery not being maxxed all the time?
完成的
Holy necro, but the way Oneplus increased the mAh capacity was by relaxing the voltage restrictions, so the battery is charged to a slightly higher voltage. The op3 would just not charge it to that higher voltage, if it didn't start complaining because the battery isn't the right model number.
完成的
添加一条评论
I wish it was as simple as Jerryrigeverything made it out to be, but I tried this a month ago and it's just not worth it the hassle. It did work, but only with the earliest rom, as soon as I updated it or flashed a custom rom I would either get the Linux penguin logo or I'd get a message while booting that the battery was incompatible. If you're in need of a new battery I seriously recommend going with the original battery. :)
这个答案有帮助吗?
得分 0
添加一条评论
The Oneplus 3T Battery has a slightly higher nominal voltage wich will interfere with the oneplus standard 3.8 nominal voltage. So it is not recommend and probably not possible to do it.
这个答案有帮助吗?
得分 0
添加一条评论
Technically you can, but there is a very high possibility that it will only charge the battery to 3000mAh instead of 3400mAh. The batteries also have different voltages. (Watch JerryRigEverything’s video if you want to see it attempted: https://www.youtube.com/watch?v=n1sg2y8O...)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tommy Vercaty 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 10
过去的30天: 72
总计 8,970
