跳转到主内容
Recent apps hardware button stopped working
Yesterday when I took a shower, I think my phone may have gotten splashed with a little water.
After a bit of use today, I noticed the right hardware button wasn't responding to being touched. The button worked fine last night after my shower, so I hoped it was just a software problem. I rebooted and cleared the system cache in recovery, but no dice. I also tested the button in the *#808# menu, and it failed to register input. Interestingly, the button still lights up when the home or back button is pressed.
Everything else on my phone works normally. Does it seem conclusive to you guys that water damage is the cause?
If so, would you recommend attempting the repair? I'm pretty handy (work on my car, built a PC, etc) but I've never taken a phone apart. I watched the video, and it didn't look too tricky, but I won't attempt it if there's a good chance that I could easily damage other parts of my phone when attempting the repair.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Did u fix? I got same situation splash water.
这个答案有帮助吗?
得分 0
2条评论:
Yep, completely drained the battery, fully recharged it, and turned it back on. Problem solved!
完成的
This worked for me, thanks!!!
I had both Back and Recents button not working. Had to do the procedure twice to get both to work.
完成的
添加一条评论
添加你的答案
Reid Prichard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,848
