跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
293 个问题 查看全部
Screen appears to have soft wrinkles after replacing camera
I bought an iPad that needed a new rear facing camera.
I CAREFULLY opened the iPad, disconnected the battery, found the defective camera, replaced it, reconnected the power supply, and now the screen appears to have soft, undulating wrinkles on the upper half.
Looking for any answers!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
Hi and thanks so much for your response.
The initial problem with the iPad was a bad rear camera, which is why I opened it. I used playing cards to pry the digitizer off and might've accidentally dug a little too deep between the digitizer and LCD. Pulled out two small pieces of 'wire fabric' looking stuff from one edge of the joint between the digitizer and LCD. I never even detached the connector or took off the cover plate.
这个答案有帮助吗?
按维修分数 0
添加一条评论
That sounds like it might be a loose connection or damage on the display cable. I would attempt to reseat the display cable and try again. When you reseat the display cable, don't put the iPad all the way back together before testing to avoid needlessly replacing the adhesive multiple times.
这个答案有帮助吗?
按维修分数 0
添加一条评论
Try not to tighten the four lcd screws to much, if the problem still remains try applying a little heat from a save distance. This could help retract the wrinkles.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Craig Sweeny 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 24
总计 219
