跳转到主内容
Repair and disassembly guides for remote controls.
57 个问题 查看全部
Yamaha RAV238 Remote Volume Buttons Inoperative Everything Else is Fine
Hi, this AVR (Yamaha RX-V1400) got moved upstairs and for some reason the volume buttons on the remote RAV238 stopped sending to the AVR. Every other button I touch does send (the red light in the upper left shines when a key is pressed). It's just the volume up / down (press them, no red light) that are the only keys not working.
Any suggestions would be appreciated.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
This seems to be a common problem and I don't know how to fix it either. Good luck to both of us because a new remote is $75!
完成的
It's the black press button on the inside that is worn out. I have tried a number of ways to clean it but it only works intermittently. I used other buttons on the silicone base and it worked fine, so isolated to this up button. Looking for a new remote.
Geno
完成的
You can buy a special repair kit for remotes at electronics stores, the kit will have some patches for those black connectors and some glue to attach them - works fine.
完成的
添加一条评论
14个答案
已选择的解决方案
same problem on Yamaha RX-V650 remote. but it's quite easy to repair it.
1. open battery housing and remove the batteries
2. remove the screw located in the center of the battery housing
3. top and bottom shell of the remote are held together by 4 latches per side. the most fore and aft ones are located about 1cm from each end. pry them open w/ a small flat head. if you're carefull that will leave only tiny scratches, but it does take some force
4. once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote (mine was full of... stuff)
5. if necessary, at contact spray or alike to the buttom of the rubber buttons
6. put it all back together again. you might need some new batteries as well. should work like a charm
PS: I made a repair guide.
这个答案有帮助吗?
得分 21
15条评论:
+...nice and useful guide :)
完成的
Andre, you are a genius!
Thank you soo much!!
完成的
Superb. My yamaha remote is working great now.
完成的
Thank you so much. I was about to order a new remote when I discovered your comment. This saved the planet unnecessary waste and saved me money. In my case, a previous cleaning of the remote from the outside must have caused some cleaning liquid to get inside and accumulate below the 'off' button and the volume controls, which are very important buttons :). After opening the remote, cleaning of the circuit board with alcohol and Q-tips made a huge difference, and the buttons work when being pressed lightly now. Opening the remote was hard. I assumed that both parts were glued together, until I read your post. I would not have attempted to apply so much force. But after reading your instructions I knew it was ok, and sure enough, it worked perfectly.
完成的
Your advice worked great, and now the volume buttons are working again with no problems. I did notice the only "slime" was directly under the buttons of my Yamaha RAV 331 volume buttons, and since they are the ones pressed at the highest frequency by far, that maybe the rubber itself is expressing the slime over time and usage. No matter where it originated, taking the unit apart per your instructions and cleaning with the Zeiss lens cleaning wipes I had on hand did the trick. Thanks again.
完成的
显示更多的10条评论
添加一条评论
Next for me was the power button not working. I was about to buy a universal remote then thought, I'm going to spend $75+ on an on/off and volume up/down button?
So I gave opening the remote one more try seeing as I now had nothing to lose. Found a decent smallish flat head screwdriver and started to pry - con gusto. Pop came the first one and prying around the remote I was able to open it all up.
In my case it wasn't so much dirt as some sticky film on the buttons. In the holes of the rigid plastic was some debris which I scraped out. As for the film, no doubt a late night spilled scotch, I just went at it with paper towel and the flat head acting as a mini scraper.
When it all looked about as good as it could get I put it back, reinserted the batteries and the thing came to life. Tested it out on the plasma and holy cow I now had both power on and volume up/down.
For some reason I feel like blowing $75!
Thanks André. Had it not been for you I would never have attempted this.
bob
waterloo, ontario, canada
这个答案有帮助吗?
得分 1
1条评论:
I was discouraged that my buttons were fine but remote control didn't work. I popped off cover to batteries, removed and inspected inside...there was some kind if film/debris blocking the connection from spring to battery! Took off cotton from qtip and cleaned it with rubbing alcohol and voila it works now!
Good luck & think outside the box before spending money on replacing the remote!!!
完成的
添加一条评论
Both of these descriptions are correct. I would only add that YOU GOTTA BEIEVE. It is very difficult to pry this thing apart. I found that starting near the bottom, along the long edge, and prying with a thin but wide flat screwdriver worked. Once the first latch pops out, slide the blade up until you can feel the next one holding and pry again - much easier.
Once apart, a Q-tip and some alcohol on both the PCB and the buttons will clean it up nicely. Works perfect now!!
这个答案有帮助吗?
得分 0
添加一条评论
I was in the Same boat and knew the remote was done so opened the back and moved different pads over the the volume tab and it worked. The pads that I didn't use more or less the same size and cut the square out and replaced the good one with the bad one. It works and saves you having to find a new remote.
这个答案有帮助吗?
得分 0
添加一条评论
"System power" button needed hard pressing even after cleaning. So I cut small piece of aluminum foil and placed it between circuit and pad. Now button works as normal. Well... who knows how long it will work but now it works 8^)
这个答案有帮助吗?
得分 0
添加一条评论
This worked GREAT. I would only add that alcohol wasn't sufficient to clean it in my case. Although the contacts "looked" clean they didn't work... I could reposition any other key over the pc board position for the volume and it would work. So it was the carbon film on the bottom of the button causing my problem. I tried cleaning them with 1500 grit emery paper and still nothing. I tried the aluminum foil trick. That worked but I was concerned about what sort of unwanted contact it might make if it slipped after I started using it. So in desperation I wet the emery paper in alcohol and "wet sanded" the carbon film. THAT WORKED!... Now it's like new. Thanks for your info on getting the thing open and the overall approach!
这个答案有帮助吗?
得分 0
1条评论:
mine had dried coffee shorting out on/off button on pc board, alcohol cleaned it up nice, no carbon build up ....works great now!
完成的
添加一条评论
David can someone have control of your amplifier volume outside your home because i have volume at the right setting when watching tv or a dvd it goes up then i have to turn my volume down and it goes down also
这个答案有帮助吗?
得分 0
添加一条评论
Had the same problem on a model purchased in 2016 and realized the problem. Make sure the remote is not on the wrong zone!!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
My problem was the “power off button” slow to response or not at all.
Best Advice: The “hard to open case and PRESS” the plastic hard and harder; after it might get small dents on the plastic cover, but it will get it open (BTW I did use a spatula or same called knife for plastering, worked great) . Once opened: I did clean wit a q-tips with alcohol an oily spot under on the “power and pause” buttons. Put it back together and voila!, worked GREAT. Thanks so much for this advice and post.
这个答案有帮助吗?
得分 0
添加一条评论
Ditto on appreciation for this fix. Just want to add a word of caution that hopefully saves others. My Yamaha RX-v659 remote has the multi-function slide button on the side (Source/Amp/TV). The metal prongs are more fragile than I thought…broke one of mine with a q-tip. Any suggestions on how I can fix this?
这个答案有帮助吗?
得分 0
添加一条评论
dried spilt coffee residue shorting out on/off button on pc board, cleaned with alcohol and q tip, works great now!
这个答案有帮助吗?
得分 0
1条评论:
Great advice! All of the buttons were becoming intermittent but volume buttons didn't work at all. After trying to reprogram the remote with difficulty (the reprogram button was also flaky) I found your post about disassembling and cleaning things. Scrubbing the PC board under the buttons with rubbing alcohol on a paper towel removed lots of contamination. To be sure, the button membranes were also soaked in alcohol and scrubbed with swabs before everything was dried and snapped back together. It works like new now. Start prying the remote apart at the bottom followed by working your way around to separate the rest. This will leave some marks but in a less noticeable area. Thanks again.
完成的
添加一条评论
My yamaha RX-N600 Avr remote 324 power button work when press hard how to fix it actually my sister child reset that remote ,I enter all setting codes but its still half working
这个答案有帮助吗?
得分 0
添加一条评论
Mine doesn't show anything on the LCD and when I look at the signal window via cell phone or camera I don't see any signal being sent. Any suggestions?
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
Wow, amazing! Couldn’t figure out was only volume wasn’t working, but obviously wasn’t a battery issue. Opened it up per these instructions and there was sticky residue around these buttons, letting it dry overnight before putting it back together but I did a quick test and it worked!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bob 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 43
过去 30 天: 198
总计 58,551
