My phone won't charge
My phone had 1 percent battery, I plugged it in the charger and charged it all night and when I got up the next morning, it still only had 1 percent battery.
First try charging the phone with a different cable. If that doesn't work check the lightning port for any residual lint. Power the phone off and stick the end of a paper clip into the charging port to remove any debris. If that doesn't work the next step is replacing the lightning port, then the battery.
这个答案有帮助吗?
how do i change the lightening port when all else fails and is it possible to charge it wirelessly???
Turn off you phone when charging . Use another flex cable or charger to have a try.
这个答案有帮助吗?
17 hours from now by JennyMay Roma Witters Murrin
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,858
