跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
Charging connector and battery replaced but still not charging
My iPad 2 didn't charged so I replaced both battery and charging connector to be sure.
The iPad starts since their was a 60% charge in the new battery, but it still doesn't charge!
Is their another part that can be damaged?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You likely have a damaged charge circuit on the logic board. This can be damaged by using non-original chargers and cables (or worse, car chargers). It can also be caused by drops or just plain spontaneous failure. Normally this would require a micro-soldering repair and is not DIY.
However, aftermarket batteries and small parts are notorious for poor poor quality so it is possible that you have a defective replacement charge port.
这个答案有帮助吗?
得分 2
添加一条评论
Jonathan, iPads and iPhones have an integrated chip (IC) called the Tristar chip that governs USB charging and recognition. If you have replaced both the battery and charge port and still no charging then it is possible that this Tristar chip has gone bad. That's not uncommon since they are sensitive to voltage surges or "dirty" voltage that most often occurs when using cheaper 3rd party charging cords. Apple charging cords and certain higher quality 3rd party charging cords have components that protect against bad voltage.
The Tristar chip can be replaced. It requires microsoldering equipment and expertise though.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jonathan Stenberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 88
