跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
iPhone 6s not turning on or charging
Hi all, so last week I bought a battery replacement for my iPhone 6s from ifixit. All the installation went well and I got to use my phone the whole week until this morning. So, my battery was low last night so I decided to let it died completely and thinking to charge it this morning. When I woke up and plugged in my iPhone, there was no battery symbol on the iPhone. its like it is not charging at all. I plugged in for like an hour and tried to turn it back on but nothing works. I even tried hard reset but no luck. let me make this easy
_ iPhone's battery died completely overnight
_ plugged into charger in the morning but its not charging
_ can't turn on or do anything about it
_ tried hard reset but not working
anybody can help me please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Try using another battery and if it still does not charge then you have a charging U2 IC problem which needs professional repair.
If it works with new battery, the other one was faulty.
这个答案有帮助吗?
得分 1
添加一条评论
possible power ic issue (simple way to put it) which would be repairable by a main board specialist.
quick test is open phone, disconnect battery , plug phone to mains and see if apple logo appears after a few seconds (it will appear for a few seconds , go off and repeat)
if the apple logo appears then its a good indication you have a power ic issue . if it doesnt then could just be a defective battery . aftermarket batteries are pants tbh
这个答案有帮助吗?
得分 0
3条评论:
to followup were your original battery issues plagued by major drain even when phone not in use.
完成的
I got the exact some problem before with my original battery. It all fixed when I replaced it with a new battery tho. But now it happened again.
And both original and my current battery drain very fast. its just keep draining even when I'm not using it
完成的
when you said "plug phone to mains" do you mean plug the phone to the charger when the battery still disconnected?
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,250
