跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4844 个问题 查看全部
Is this real reball bga and fix pin pad
http://www.fixphoneshop.com/efix-ip-bga-...
https://youtu.be/kDJwrhmfCm8
Are that real with uv light and green paste
And is this real
Icloud remove
https://youtu.be/o7cA-fmHaq0
Is it fake or real
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Apple Watch 套装
Screen and battery repairs just got easier.
现在开始购物
Apple Watch 套装
现在开始购物
2个回答
已选择的解决方案
The first part of your question has to do with UV-curable solder mask. Yes it is real and it works very well for what it is meant to do. If you have damaged solder mask on your printed circuit board or underneath main IC's like a NAND (perhaps from scraping with de-soldering braid), then you can apply the mask and cure it with a UV lamp.
The second part of your question has to do with iCloud unlocking via hardware. Yes it is possible to do this but requires a matched CPU, NAND, BB and EEPROM. You would get this from a donor board. Frankly, it is a very, very advanced repair and not really worth doing unless you were an expert. They do it for cheap in China but to have this done in North America is cost prohibitive.
这个答案有帮助吗?
按维修分数 3
添加一条评论
I would like to add to Minho's answer here a bit.
Just because I know how to use a knife doesn't mean I can do brain surgery!
You won't need the masks or the UV mask material for general iPhone, iPad or Mac repairs. If you do remove SMT devices you might need the UV mask material to patch the logic board.
If you follow the iCloud vid you would see the person is using professional soldering gear to rework the iPhone board, This gear is quite expensive! Even still, it's more involved than popping of a chip to clear the iCloud info and you would still end up having a crippled phone in the end!
Bottom line spending $5000 or more dollars to get the gear to do this is not economically workable! Besides you are then helping the criminals who stole the phone! One day it could be you hit on the head left to die by the crackhead who needed a fix.
这个答案有帮助吗?
按维修分数 2
评论:
Good points Dan!
添加一条评论
添加你的答案
Peace nguyen 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 8
总计 249
