Why the car is consuming more fuel
The car showing no other symptoms.but the fuel consumption is double than usual.
A more detailed question should be asked. What type of engine. Is the check engine light on. When is the last time you had a tuneup? My guess is never...
Double the fuel consumption you either have drag (issue with the brake system, seized calipers), sensor(s), fouled plugs, air filter clogged, vacuum leaks, a fuel leak, under inflated tires. Although it won't be a tire issue..
My guess is start with a tuneup, plugs, filter etc..
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,190
