跳转到主内容
A lawn mower made by the American Company Toro
119 个问题 查看全部
My brother killed it cutting on ground that was too steep
The spark plugs is new new gasoline cleaned float bowl main jet needle valve starts on starting fluid dies immediately
Won't start without starting fluid?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you pull on the rip cord a few times then pull the plug is the plug wet. If its not then your not getting enough fuel . When resetting the need valves run them in till they bottom out . Don't over tighten then back them off 1 and 1\2 turns. hope his helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Erwert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 37
