跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Won't boot past Firevault login screen.
The computer boots up and I login and it won't go past the Firevault login screen, the loading bar is slow and when it's full it's just hangs
I tried ASD and it found not issues
Booting into disk utilities is the same thing, it boots and loads slowly and hangs at the apple logo.
Tried safe mode and nothing changed
Charging was weird at the start, I would plug in my charger and no lights but now it works normally.
Finally my friend who works at the apple store did a diagnosis and it said "Management engine failure". I have no idea what that means though.
Thanks to everyone that can help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ah! You encountered the Intel Management Engine (I-ME) download failure!
As you have a Fire Vault enabled disk you have a problem! We have a 'Chicken and Egg' problem! The system needs access to the drive to unlock the system but the drive or the access key has a problem!
You'll need to take the drive out and using either an external drive or a clean replacement drive boot the system up under it (if you can't do this the logic board has a failure).
You'll still need the FileVault recovery key to gain access to the data on your drive.
Here's a good write-up on FileVault: Use FileVault to encrypt the startup disk on your Mac
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carter Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 552
