跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
'Camera not found' after home repair.
So, problem 1: I dropped my phone, and the rear camera started buzzing loudly. Someone here said that replacing their camera themself fixed the problem, so I decided to.
I open my phone, replace the camera with a spare off ebay, put it back together and open the camera. I get a 'camera is not found' error, and other apps report that they can't detect a camera.
I assume the part is a dud, so I take it out and put back the original. Still getting the error.
I assume I've ballsed something up in my fix. Has anyone else replaced a camera and had similar issues? Does anyone know what I may have done and can possibly undo?
Thanks very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
HTC One M8 are always a nightmare to repair..
I replaced a rear camera a while back and it refused to work after many replacements and re-do's.
Finally we reset the device to factory settings and this solved the issue. Hopefully thats the case here! I would try that first. It's a software issue most of the time, but also keep in mind HTC phones only like Original Parts.. So aftermarket parts are always hit or miss.
Also, with the way it's designed, it's really common for the rear camera to get disconnected during reassembly, so be sure to make sure it's connected once it's all put back together
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James Wallace 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 200
