stuck on white screen with apple logo
it is stuck on white screen with apple logo cannot turn the phone off when try to do update on i tunes i get error4005 unknown error what else can i do before taking it to tech who will overcharge me
First I'm advicing you to update your iPhone firmware via iTunes, and that will require a PC or Mac, a cable and internet connection, and update/restore, please know that if you restore you'll lost your files, incase if you get any error use the code, to rectify the proble
这个答案有帮助吗?
Try these steps:
1.Install the latest version of iTunes.
2.Force your device to restart:
a)On iPhone 6s and earlier, press and hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo.
b)Connect your device to your computer using a USB cable.
c)When iTunes asks you to update or restore, click Update (not Restore) to reinstall iOS and keep your personal data.
If you still need help, try these steps
If you can update, but your device starts up in recovery mode, follow the steps above again. On step 4, choose Restore instead of Update. After the restore completes, you need to set up your device from a backup.
If you continue to see an error during the update:
Check for updates to your Mac or PC. If you restart your computer for an update, check for updates again after you restart.
Try to restore your device using another USB cable.
Try to restore your device on another computer.
这个答案有帮助吗?
I've tried that and that's when I get the error code it could not update or restore due to an unknown problem
这个答案有帮助吗?
White Screen of Death (WsoD) is a famous error that generally related to an issue with OS and it stops the device to do any task as it displays white screen. This issue occurs especially on those iPhone/iPad that was locked due to fail of hardware component, severely dropped or when the upgrade fails .
Every iPhone/iPad users want to get rid of this error ASAP but how?
Well, you should follow the below ways to fix WSOD error on iPhone XR/XS/XS Max/8 and many others:
Way 1: Check screen magnification is disabled
To check this problem and to fix it, use you three fingers same time and double click on screen. This will help you to bring back the screen to normal if it is a zoomed. Now, to switch off the feature, go to Settings > General > Accessibility > Zoom > Off.
Way 2: Charge your phone properly
Way 3: Force restart your iPhone/iPad
Way 4: Restore iPhone via iTunes to fix WSOD error
Way 5: Switch off Auto brightness on your phone
Way 6: Use Recovery mode to fix WSOD error
Way 7: Remove battery from iPhone
Way 8: Enter into DFU mode to fix WSOD error on iPhone
Way 9: Use iOS System Repair to fix White Screen of Death on iPhone
All the above methods are effective but still some users tell that they are not helpful in getting rid of such error. In this condition, it is recommended to use professional tool like iOS System Repair to solve WSOD error on iPhone XS/XS Max/XR/8 etc.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 61,638
3条评论
So you haven't taken it apart right? This just happen randomly?
由 Chase 完成的
You should try this fix [DFU mode].
1. Open Itunes and connect your iPhone to your PC/Mac
2. Press and hold the Home button and the Sleep/Wake button all at the same time.
3. After 10 seconds release the sleep/wake button.And continue holding the home button. Keep holding the home button until you see a message saying "iTunes has discovered an iPhone in recovery mode, you must restore this iPhone before it can be used with iTunes". There you have it your if is in DFU mode.
Or read this guide "Fix iPhone White Screen of Death"
由 pattonki 完成的
It is not work
由 Sofia 完成的
