跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Touch screen won't work.
I replaced the screen and it all worked perfectly fine, but the touch screen will not respond to touch.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
Make sure ribbon #2 is plugged in the whole way. It could be it didn't snap in fully.
这个答案有帮助吗?
得分 1
添加一条评论
i tried that but the glass came off instead of the whole screen. what should i do? i think the sticky thing lost its stickiness.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue. I pulled the top screen part off even though I realize it probably wont stick as well as it used to. Then you can use a very thin small screwdriver to pry out the rest of the screen. Be very careful when doing so as the lcd screen is now exposed. Pry it from the outer edge between the case and the screen. I don't have my touchscreen working yet, but at least that will get you back into your phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
woodsidesk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,750
