跳转到主内容
A lawn mower made by the American Company Toro
119 个问题 查看全部
added oil unable to start engine
engine was smoking added oil unable to get engine to start
Update (07/25/2017)
engine was smoking added oil still unable to get engine to start.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you add too much oil? And when the engine was smoking, was it running and then started smoking and just stopped? Does the engine move? Have you checked the sparkplug? Have you tried to use started fluid? Was the engine low or had no oil in it when it started to smoke?
完成的
添加一条评论
1个答案
Was the smoke white before you added the oil? If a lawnmower engine blows white smoke out its exhaust, it means that the engine is burning oil - meaning that there is too much oil in the engine. If you added more oil to your lawnmower after it already had more than enough, you're in for a bit of trouble.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maryland cosey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 198
