跳转到主内容
雅达利视频电脑系统(VCS)有MOS科技的 6507 CPU ,频率为1.19MHz
32 个问题 查看全部
French Atari 2600 different than other European versions?
Bought recently an Atari 2600 in France and it doesn't work on the good ols TV's that I have in the Netherlands. Is that because it only works on former old French TV's?
So is there a difference in the Atari 2600's they made for the French market?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
How do you have it hooked up?
In the US atleast, the Atari uses RF which you need to connect to the Coaxial port on the TV. If you have it connected to the Composite port, that might very well be why.
And how do you know it functions? (Ignore this if you get some output showing you it works)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
michel fonville 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 10
总计 134
