跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Can't get rear camera back in
I ordered the camera off ebay. It doesn't seem to snap back into place. I tried reinstalling the old camera and it seems to work. The new camera is just a little off..
Are all the cameras on ebay pretty much the same (just different sellers)? I tried to pick a seller that sold a lot of them.
I don't think I'm doing anything on my part. I could try holding it in place and screwing it down with the plate, but I don't want to force it in there.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
eBay has a poor reputation among professional repair techs. That is usually where you will find the bottom of the barrel when it comes to parts. Small parts, such as cameras and flexes are even worse. So yes, it is possible that you have a camera that is out of spec and doesn't quite fit.
If you can easily insert your original camera but can't get the replacement one to squeeze in, then order a camera from a reputable supplier, like iFixit. You can follow this guide.
iPhone 6 Rear Camera图片
产品
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
Check the Apple Part # on the ribbon of the camera.
iPhone 6 camera - Apple part # 821-2460-03
iPhone 6 Plus camera - Apple Part # 821-2208-04
iPhone 6S camera - Apple Part # 821-00027-03
Unfortunately, they are all slightly different specs and are not compatible with different models.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 106
