跳转到主内容
Repair guides and support for your Samsung TV.
2606 个问题 查看全部
Pink rectangle and vertical lines
So my Samsung un32eh4003 TV got wet from a leak in the roof and now when I turn the tv on I get some vertical lines which go away and then a pink rectangle about 6 inches wide will appear in the middle of the screen and not go away. I unplugged the HDMI cable which was wet as well so I am assuming the connector was wet where it plugged in. I tried a different HDMI port as well with the same results and it is still there when I click menu.
Any ideas as to what this could be? Any ideas is appreciated..I was thinking main board because of the wet connector and all that but I am not sure if it is the tcon board or the actual panel itself!
Update (07/23/2017)
Do you guys need more info or suggest anything?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@jetlabbelectro what we need you to do is to check all of your boards. This is not as simple as suggesting it is the T-con board that has failed. Your's is a special case due to the water damage. Unplug your set, remove the back and take a very close look at all the boards. See if you find any obvious damage. Post some pictures of all of your boards etc. With your question. that will allow us to see what you see. Use this guide for that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jetlabb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 136
