跳转到主内容
The PowerBeats2 Wireless Headphones by Dr. Dre is a set of in-ear headphones designed for the active user.
7 个问题 查看全部
Headphones were washed and won't work!
How to fix washed headphones so they work again, if possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It's not surprising that your headphones do not work after washing. Did you dip them in water or just wiped them with a wet cloth? In any case, if water has entered the headphones and you can dismantle the covers, etc. check whether you can find wet parts. If you find water inside any place wipe it carefully with a dry cloth or paper napkins and leave them open to dry in the air. If this was the cause they should work once you put them back together. Of course there is always the chance that the water may have shorted and burnt some components in which case send them to the service facility or buy yourself a new pair (it may be cheaper than having them repaired). Oh, don't forget to check the batteries too.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
AnTHoNY FuCcI 18 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,460
