跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1509 个问题 查看全部
Turns on to apple logo then turns off after screen replacement
Hi so I've had this phone sitting in my cupboard with a broken screen for a little under a year, I got a new screen put on it, let it charge overnight and turned it on. It lit up to the white screen with the apple logo and then it turned off after about 8 seconds and this is all it does. It dosen't get picked up by my computer either :// Someone please help me out :')
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
1. Do you have Original Apple Cable ?
2. Did You try to enter into DFU Mode while connecting iP to Comp
3. Did You Tried to connect Your phone with Comp when screen is pluuged off ?
4. I can suggest You to connect it to another fully working CPU, sometimes it help
5. Was it Your first screen replacement ?
这个答案有帮助吗?
得分 0
添加一条评论
After replacing the LCD screen, you use a longer screw to install conectors protecting the sheath
. It causes damage to the logicboard
. Your troubles are similar to the "blue" screen trouble on the ip5s. I am a technician specializing in repairing broken glass display LCD's iPhone and have encountered this case many times, and have found the cause, overcome the above error.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,217
