跳转到主内容
微软第三代Xbox游戏机于2013年11月22日发布。
632 个问题 查看全部
Xbox One shutdow itself after a 3 seconds of startup
I have this problema with my Xbox one. With all then component disconnected. I connect HMDI (TV OUT), connect power brick to the wall socket. In this point I get orange light. Then Connect cable to the console, I get white light (1 second later) then yellow.
In this point all seems to normal. When I startup (using controller or press xbox botton console) the xbox one, after a few seconds (2 o 3) the console shutdown itself. No light on console and no light on power brick.
It this point power brick seems to be death. I have to disconnect from wall socket wait 5 seconds and then reconnect in order to get again a orange light
I would appreciate any help you can give me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
Hi Aracely!
Have you tried plugging the Xbox One's Power Supply into a different outlet? If that does not work, I would recommend getting a replacement power supply. From what you have described, the issue is most likely a bad Power Supply or bad outlet.
这个答案有帮助吗?
得分 0
添加一条评论
Did you get a new power brick and if so did it work I am having the same problem as you and Inam worried that my console is broken.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aracely Medrano 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 477
