Screen keeps restarting after screen replacement
I did a screen replacement for an iPhone 7 plus (oem screen) and before I put all the screws and plate on it I test it and it functions fine. When I put the front camera sensor the home button the back plate and the screws that go on the motherboard ( I made sure I didn't misplace them because that could cause the phone to get a blue screen) and close up the phone it keeps restarting just on the Apple logo. Sometimes it would go to the home screen for like 5-10 mins then it shuts back down.
I asked around and they told me it's because of the front camera theirs a sticker that needs to be intact with the camera ( if you don't heat it up good ) can this be true ? Maybe it fried the front camera and it's not letting it turn on ? Anything helps guys thanks !
I just did a iphone 7 plus screen replacement, I remove all old adhesive and apply new one. After I replaced the screen with a screen from ifixit, but 3 of them from here so far, the apple logo would show on a white background, while booting, as soon as you turn it on, but this would stay here for about 5 minutes, and flash 3-4 times before the phone reached the lock screen. I may have forgotten to disconnect the battery, but on older models, this was not ever an issue. Her phone worked fine before I replaced the screen, and to top it off, when I put her old screen back, thinking it my a new defective screen problem, the same thing happened even with her old cracked screen. Did not disconnecting the battery do any damage? The phone is brand new, even had great charging and just bought it in November. Is it possible that could have caused an issue, or did I receive a defective screen, although I do not see how because I seated the connectors very carefully and smoothly.
由 Nikci 完成的
i had same problem once thought id broke something, tried 3 screens and still nothing,i connected the screen fully connected the battery so it powered up then disconnected it for about 15 minuted then connect it again and place on charge for 10 mins, it booted up fine when i powered it on and has worked fine ever since.
由 Keith Schofield 完成的
I have the same issue but my home button is perfect. Even uses fingerprint so thats not always the
由 Lena Castronova 完成的
