13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
620 个问题 查看全部
Can this handle 8 gb memory?
hey i was wondering if you can upgrade the memory on this computer to 8gb? i kno it can handle 6 gb but if i update it to 8 gb (2x4gb) will my computer recognize it? i need sugessions before i buy it.
and btw will a 1tb harddrive work for this as well?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
According to Mactracker the A1278 will handle 8 GB and has no limit on hard drive other than what will fit in the space provided. I am providing you with a link to a guide on memory capabilities for all Macs. Look yours up for confirmation.
http://www.everymac.com/systems/by_capab...
这个答案有帮助吗?
按维修分数 3
添加一条评论
Macs tend to be picky with the amount of RAM that you have installed. I'd just stick with the recommended max of 6Gb. A 1Tb hard drive will work, but the physical size of the hard drive needs to be 2.5" wide x 9.5mm tall. I couldn't find any hard drives at 1tb, the closest I found was a 750Gb - http://www.tigerdirect.com/applications/...
Don't forget to come back and mark whichever answer is acceptable.
这个答案有帮助吗?
按维修分数 1
评论:
thanks but will this fit the macbook???
http://www.amazon.com/Western-Digital-Sc...
I would personally choose a Faster drive over that, but if you need a terabyte then go for it. That should fit no problem
No it won't fit
Oh my bad it does
Nick, I will not vote this as an accepted answer as the question was not on hard drives and his answer is wrong, "1.0TB WD Scorpio Blue 5200RPM SATA *12.5mm* HD with Advanced Format Technology - Fits all Apple MacBook/MacBook Pro 'Unibody' Models (13/15/17")
显示更多的1条评论
添加一条评论
If you want a 750GB 7200RPM (faster) I suggest this, if you really want all the space and want a 1TB hard drive, then get this one.
Regarding RAM, according to Mactracker your maximum RAM is 6GB, which you can max out using these two sticks.
PC3-8500 2 GB RAM Chip张图片
产品
$14.99
PC3-8500 4 GB RAM Chip张图片
产品
$39.99
这个答案有帮助吗?
按维修分数 0
添加一条评论
I just installed a 1TB 7200rpm drive in the A1278 model. It is 2.5inch and 9.5mm height. Works fine.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
sai 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 9,284
