跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
174 个问题 查看全部
iMac 21,5" late 2012 lcd backlight not working
Hi,
This iMac has no backlight anymore. the diagnostic leds are all oké. Is this a broken lcd or is this a logic board problem?
Thx for the reply
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Using a flashlight can you see the faint image of your desktop icons? You'll need to hold the flashlight at a sharp angle resting on the screen to see.
You might also want to check things using an external monitor as well.
Let us know what you find!
完成的
Yeah, I can see the desktop icons with A flaslight. Will try with an external monitor
完成的
添加一条评论
1个回答
已选择的解决方案
Sadly, this implies your logic board needs repair. Either a fuse link or more likely the backlight LED driver burnt.
这个答案有帮助吗?
得分 1
评论:
I did the test with the external display and this is working fine... So still the fuse or backlight LED driver?
完成的
Without opening and testing things out I'm just guessing here ;-} The good news its' not as bad as it could be!
You'll need to find someone with the needed skills & tools to dig into repairing your logic boards backlight circuit. This is beyond most DIY and you would still need to find the needed parts which can be tough.
完成的
添加一条评论
添加你的答案
Mattis 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 8
过去的30天: 13
总计 474
