跳转到主内容
修复你的物品
维修的权力
商店
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
4450 个问题 查看全部
How diagnostic from usb key?
Think my logicboard is dead, black screen, just HDD who is power on nothing else, opical drive do not respond at all
How to realize an hardware diag from external usb key cause to put "D" key at startup do nothing
thks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I'm not sure I understand. Your symptoms point to a dead logic board, but what are you attempting with USB?
完成的
With 24h, no changes, I have power cause I can heard the Hard drive power up
Think its logic board definitivly
thx
完成的
yes and no chime even if I keep power button on during a while...
完成的
添加一条评论
2个回答
最有帮助的答案
Grasping at straws here...
You could try removing the battery, unplugging the power, and letting it sit for 24 hours and see if that brings it back to life.
I assume you're not getting the startup chime? If you are, there are other steps we could offer.
Have you considered it may not be getting enough power? Do you have access to another power adapter to try? Try it without the battery installed.
这个答案有帮助吗?
得分 1
添加一条评论
I hope an usb diagnostic tool in order to confirm if logic board is dead or not cause I m not confortable to buy another logic board just for fun !
这个答案有帮助吗?
得分 0
评论:
Unfortunately if the logic board is bad the USB ports most likely will be dead. Ralph
完成的
添加一条评论
添加你的答案
Gregory 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 901
