跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 left side portion cant be touch
Hi guys :) I have an iphone 5 after removing it on charger the phone cant be pressed and having a ghost touch i tried almost everything restarting etc still nothing happens so i decided to remove the screen and boom the phone is already working after cleaning the flex cable but i have a problem the left side particularly on letter q and 123 sign cant be pressed how can i fix it i need help plss
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is a simple fix but maybe not what you would like to hear. If your having touch issue or ghost touch, then your going to need a new screen on your iPhone. If certain buttons do not touch in the same specific spot then it sounds like you have some flex cable damage or LCD damage on your screen. Here is a link to purchase the parts and also the repair guide:
iPhone 5 LCD and Digitizer
iPhone 5 LCD and Digitizer图片
产品
$39.99
这个答案有帮助吗?
得分 0
4条评论:
i saw a very light /unnoticeable vertical line on the affected area what this could be ?no sign of damage on my lcd .Can i just clean my flex cable or board ?To solve this problem ?
完成的
@theiphoneguy07 pls can you answer my question thanks in advance
完成的
You can try that, but what makes you think that the cable connection would need cleaning? Did you get your phone wet? There really isn't any other reason why those connectors would need to be cleaned. As for your screen not being broken...the glass is much more flexible than the digitizer. The faint line is an indicator of a broken digitizer, which is what senses your touch. It's very common for people that carry their phone in their back pocket to have this type of damage.
完成的
So my digitizer might be damage ? i think time to say goodbye to my iphone 5 it doesnt deserve repair i need to upgrade already
完成的
添加一条评论
添加你的答案
Fixie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 91
