跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Why is my phone not turning on?
This morning, my phone's power button and home button were not responding. I shut the phone down, which resolved the issue. Then the phone started turning off by itself. I would power up the phone to only have it shut off 2 minutes later. Then a static noise starting coming out of the speaker while it was on. It's now not turning on at all. The battery was at about 45% when this started happening. I've tried to hold the power button and volume down button...the Galaxy logo comes up and then shuts off again. And that only happens about half the time. The other half nothing comes up at all. I tried plugging it in, hoping a charge might help, but it has not. The phone is no longer plugged in but the red light is still on. Any insight would be appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
And if you want to reflash firmware on the phone without using wiping data follow these steps:
http://updato.com/how-to/how-to-install-...
这个答案有帮助吗?
得分 2
添加一条评论
Hello danielle ,
it seems some issue occur of your firmware,
1) download smart switch
2) select emergency recovery & initialization where located at right side
3) put the phone to download mode by pressing and holding (simultaneously) the Power, Volume Down and Home buttons
4) select continue option
5) follow the instruction given by smart switch
6) Wait while process completed
7) you almost completed!!!
Note : you have your own risk to do above steps!!! around 3GB-4GB of internet data will be required to download firmware.
Hope this solution helps you to fix your phone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
danielle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,054
