跳转到主内容
由华硕制造的笔记本电脑。
2523 个问题 查看全部
My asus won't boot completely up after I tried to reset it to default.
My asus is a k55a and it continually reboots when it suppose to kick it a windows 10 troubleshoot after a while and if I can get there i can finish resetting my laptop. I have windows installed on a flash drive for backup, didn't know if that mattered. all I can pull up is the Aptio Setup Utility but there is no csm option or Secure boot control. So it not letting me change the boot option, also don't know if that matters but the more details the better. anyway I was trying to boot it from that usb.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If this problem started after an update (or system reinstall), please make sure the laptop is not connected to the internet in any way before you use the following instructions.
Try the following...
1. Power off the laptop.
2. Power on the laptop.
3. As soon as you see the rotating loading circle, press and hold the Power Button until the computer shuts off.
4. Repeat this process a few times until you see the "Preparing Automatic Repair" screen.
5. Now you want to let the laptop boot to the "Automatic Repair" screen.
6. Click "Advanced Options" and then select "Troubleshoot".
7. Here you want to select "Refresh your PC", if you do not wish to erase data, or "Reset your PC" to erase all data and restore your system.
8. From here just follow the screen instructions until the recovery is completed.
NOTE: You will need to get into the "Advanced Options" in order to get the "Refresh Option". This choice will keep your data, but any programs installed will be lost.
Do not do a "Reset" as that will wipe all data you have on the laptop.
Otherwise, MiniTool Partition Wizard can help you some way and the team had provided 8 solutions to solve this problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Blake Stine 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 208
