跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
Both iPhone Camera's Not Working
Both my iphone 6s cameras (front and back) have stopped working after a drop, I have restored my phone because i thought it could be a software issue but it's not, all microphones still work though and everything else works as normal so does anyone have any idea of what's happened and what will need to be replaced and how i would go about replacing it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Though difficult to diagnose or give suggestions without being able to inspect it, I would first do what you have done...open it and unplug battery before starting. Then attempt to reseat the connectors. 2nd I would try a hard reset by holding the home and power buttons down for 10 seconds or so to reboot. Connect to iTunes and do a backup, in case you lose power, or some other issue occurs so you don't lose data. Maybe even doing #3 first....
Does your flash or flashlight still work?
It could be a hardware issue where a component has broken a solder joint and would need microsoldering done.
You could even restore your phone to see if it is software, but doubt it since the symptoms began after a drop.
If none of the above work, you could try to find a micro soldering shop close to you locally or look through the pros here on iFixit and you may be able to find someone where you can mail the phone in for repair at a reasonable cost most don't charge if the repairs unsuccessful so you have nothing to lose that way
这个答案有帮助吗?
得分 2
添加一条评论
Hello
Maybe when you drop your phone the shock was fort the camera was move from is place or the cable from the logique board
Good luck
这个答案有帮助吗?
得分 0
1条评论:
iv already taken the camera out and reconnected it so i don't think it's that
完成的
添加一条评论
Don't really know how useful it will be for iPhone 6s but the "fix 6" given here https://yalujailbreak.net/iphone-7-camer... worked for my iPhone 6.
这个答案有帮助吗?
得分 0
添加一条评论
You can make the the iPhone camera working by installing Cydia for iOS 11 on it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh Griffiths 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 219
