跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
286 个问题 查看全部
SSD in SATA slot?
Hey!
I'm thinking about getting the 2017 iMac, but something's confusing me. Correct me if I'm wrong, but it looks like there's still a SATA connection for the HDD portion of the fusion drives. Is there something wrong with replacing that with an SSD? If it's just a SATA connector, my first thought is that you could pop an SSD on there and call it a day.
Let me know if anyone has any experience with this!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Apple has two drive connections in this series: One is SATA which is supporting the traditional spinning disk HD. The second drive connection is a custom PCIe x4 that supports a custom blade SSD.
The issue you need to think through is if SATA III (6.0 Gb/s) SATA connection is fast enough for you. Vs the much higher PCIe SSD connection x2 (16.8 Gb/s) x4 (28 Gb/s) offers.
A Fusion Drive is a dual drive setup (both drives) which are seen as one logical drive. You can break the fusion set to get access to the discreet drives. And yes you could swap out your SATA HD for a SSD but you can't use two SSD's in a fusion drive setup.
I recommend getting the largest PCIe SSD model you can afford and then later either add a SATA drive or better yet setup an external Thunderbolt RAID drive so you gain the better performance of the RAID set.
这个答案有帮助吗?
得分 2
添加一条评论
If it has enough room for an SSD, then yes. Apple tends to try to use as little space as possible, so a SSD that is the size of a 2.5 HDD might not fit.
Good Luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Mayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 210
