跳转到主内容
加入维修社区 - 创建账户
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
Piece of rubber hanging down from needle
My Keurig 2.0 is working but there is this little rubber piece that is hanging off from the top. It is a straight piece that then ends in a little rubber circe. The circle is broken.
My daughter is planning on taking it to college with her in September and I was wondering if I can fix this little piece some how.
Update (06/29/2017)
This is a picture from under my machine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Answer is related to the mini-pump, but the question is about the needle seals.
完成的
this looks like a black rubber washer. Why can't I find them anywhere?
完成的
添加一条评论
2个答案
最有帮助的答案
This is the seal washer for the needle. I don’t recall why there’s two parts to it. I think mine only has one. It seals between the machine and the top of the pod.
This might work to fix it: https://www.amazon.com/Replacement-Needl...
https://www.bonanza.com/listings/Keurig-...
这个答案有帮助吗?
得分 3
2条评论:
The item from Bonanza should work since my Keurig is a 2.0 K400. The part is a little pricey, but it's cheaper than a new Keurig. I also don't know about the 2nd attached piece, but I guess I will find out! I will order this and keep you posted. Thank you for all your help in locating this part.
完成的
@willpsree thanks for posting the link excellent find since those O-rings have a tendency of disappearing!
完成的
添加一条评论
This guide shows you the tubing:
Keurig 2.0-400 Mini Pump Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Phyllis Jozwik 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 41
总计 10,894
