跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
strange colors on back camera
hey people, i got an iphone 5s with strange colors on the back camera. if i bend the phone it gets worse. doe anyone has experience with this sort of defect? i already tried a different camera .
(picture is a iphone 5 , just for example)
Also i got an 6s with back camera and flashlight problem. when i change the camera nothing happens, when i put a jumper at camera ic the flashlight starts working again but no back camera. anyone got some advice on that one too?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Seems weird i got a 5s too and dont have this problem
这个答案有帮助吗?
得分 0
添加一条评论
can you open your camera? if not follow ifixit rear facing camera guide here
iPhone 5s 后置摄像头更换
on Step 18, dont' remove any of the lcd connector. but touch and try to fix camera cables. (strips). Turn on your phone. and open your camera app (no need to fully reassemble your screen for a while.)
Now when camera is ON, and you can see camera's view on lcd.. try to press camera strips. if you see abrupt behavior of camera... it must be your camera's strips broken.
if nothing changes, remove all LCD connectors from step 18 to 23 following that guide. i mentioned above.
and remove camera's connector.. remove camera out.. try to adjust it's strips from end to end. fix it back.. connect all connectors and check again. if anything change or not...
If it is fine. Thanks GOD or else.. you need to order a new camera for 5s from any online store. I use AliExpress you may use any one.. ebay or some other store.
这个答案有帮助吗?
得分 0
3条评论:
hey! thanks for your long answer but i already tried another camera so it must be on the motherboard
完成的
so.. if this can be fixed you should.. otherwise.. I had blue screen issue with my motherboard. (that mean dead). I ordered one from china (AliExpress) and replaced myself. although that costed me around 100$ but that is still working great.
完成的
yes okay, thanks for your help
完成的
添加一条评论
添加你的答案
thieske 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 625
