跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
Is it possible to repair this dent?
I bought this MacBook used, it was fairly dented up, and I just dropped it making it worse. Is it possible to pound this dent out, or should I just get a replacement case on eBay? Here are some pictures .https://plus.google.com/+dastumer/posts/...
Do you guys think it is worth repairing? It bothers me quite a bit, but I'm a bit hesitant to do a full teardown.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
There is a lot more downside than upside. You can't fix the dent without getting inside the case. I would leave it alone and learn to love it.
完成的
添加一条评论
3个答案
已选择的解决方案
Yes it is possible to fix, of cause.
You will need to grab an upper case from a dealer, and you can keep your lower case as it has your serial number printed. If you don't care about the serial, you can also replace it anyway.
Is it worth a fix is totally up to you, as you are asking, I assume you want to fix it, then it is worth fixing!
You don't have to do a "full teardown" to replace the upper case, but it's almost a full one.
There is a guide describe all the steps you need to replace the case.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, I tried pounding it out first to see if I could make a difference, I might replace it in the future.
完成的
添加一条评论
Just for future people, I managed to get the majority of the dent out by hammering at it using a wood block and ball peen hammer for the straight sections, and popsicle sticks and wrenches to push out the corner. Here's pics : https://plus.google.com/+dastumer/posts/...
这个答案有帮助吗?
得分 1
添加一条评论
this is video https://www.youtube.com/watch?v=cZlBHk4B...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
da stumer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 24,406
