stuck on press home to update!?
Home button not working. stuck on white screen saying press home to upgrade. tried restarting and plugging into computer. help?
Try a hard reset first of all, on iPhone 7 long press on power and volume down for a few seconds, the phone will shutdown and restart, once you see the Apple logo release all.
这个答案有帮助吗?
i did and it just brought me right back to the press home to upgrade. isnt that just a soft reset though? thank you anyway
The same issue is happening with me. Austin Harris, what did you end up doing? restore?
Long press the top power button to slide to power off. Then turn on. It should prompt you to choose language if you have done a restore. Then you can activate device and turn on assistive touch for home button function.
这个答案有帮助吗?
None of those tips helped me .
It seems like iOS11 no longer gives you the option to slide to power off after update.
I suppose holding volume down + power may help?
Sounds like the only way is to open up the phone and unplug the battery?
Press and hold Power button and Volume down and it will go into recovery mode.
Then connect to i tunes.
这个答案有帮助吗?
i have a solution. when iTunes finish updating your software, it will prompt you to keep the phone plugged with USB, but you have to unplugg it and turn your iphone on again and than connect it to itunes and manage as a new iPhone.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 12,926
3条评论
Tried using DFU mode to restore with the volume button + power method but it keeps kicking out of DFU mode before the restore can start!
由 Austin Harris 完成的
This seems to be a pretty common problem. Does no one have a solution?
由 Austin Harris 完成的
<a href="http://www.bangnapi.com">detik com</a> Membaca berita sudah bisa dilakukan dengan cara yang sangat mudah, kapan pun dan di mana pun Anda berada. Anda hanya perlu membawa sebuah handphone tanpa ribet membeli koran atau surat kabar, karena di internet banyak situs-situs berita yang selalu update informasi yang hot dan aktual. Di Indonesia sendiri, ada banyak sekali situs berita yang bisa Anda kunjungi. Dan tentu saja Anda bisa mendapatkan berita hangat dari berbagai macam topik, mulai dari berita kesehatan, politik, sports, pendidikan, ekonomi, sosial, dan lain sebagainya. Selain itu, berita yang tersaji online tidak hanya sebatas berita nasional, tetapi juga banyak berita internasional yang akan Anda temukan. Nah, apa sih Situs Berita seperti detik com ? bangnapi.com
由 Matcha Latte 完成的
