跳转到主内容
加入维修社区 - 创建账户
Google Home 语音激活扬声器,配备 Google Assistant。于 2016 年 10 月 4 日发布,并于 2016 年 11 月 4 日上市。
My google home has stopped working completely
When I turn it on I get 2 vertical lights, then a cross of 4 lights, and this repeats....
It's not connecting to the internet, and not responding to any questions
This started about a week ago. For the previous 6 months it has been ok
I suspect its a software update problem. Can you help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
7条评论
Could you take some pictures of both lights?
在已经存在的问题里加入图片
完成的
I have the same problem but I have no lights whatsoever on mine
完成的
lights turn on but alexa doesn’t speak
完成的
My Google Home is not working
完成的
Google home says it's not connected to the internet
完成的
显示更多的2条评论
添加一条评论
6个答案
最有帮助的答案
Each of these won’t take more than a few minutes at most, so when Google Home doesn’t respond:
Press the microphone mute button to see if Google Home was muted accidentally.
Unplug Google Home before waiting at least a minute to plug it back in.
Gently blow on both black dots on the top of Google Home, and then wipe the top with a soft and dry
Perform a factory reset by pressing and holding the microphone mute button for 15 seconds until you hear the confirmation from Google Assistant. A factory reset will clear all personal data from Google Home.
这个答案有帮助吗?
得分 8
添加一条评论
I had the same issue with my Google home.
But after updating my home address, its work like a charm. Update your as well:
Open the Google Home app on your Smartphone → Tap on the hamburgerMore settingsGoogle Account settings → Update Personal info.
If this solution does not work for you, then try some other fixes to solve Google Home not responding problem.
这个答案有帮助吗?
得分 5
1条评论:
The new google home update crashes upon setup. I have Android 4.4.2 so it "should" work. Jimmycurk@gmail.com
完成的
添加一条评论
It was a software update issue. Had to reboot the whole thing and reset it…..
这个答案有帮助吗?
得分 3
添加一条评论
Chinese troep. Ik heb het probleem niet meer. Ik heb het in de vuilnis gegooid
这个答案有帮助吗?
得分 1
添加一条评论
My Google home not working
这个答案有帮助吗?
得分 1
1条评论:
Past 30days:179 not working
完成的
添加一条评论
It’s not responding
这个答案有帮助吗?
得分 1
1条评论:
What do I do to get. google to respond. She stopped responding yesterday.
完成的
添加一条评论
添加你的答案
Andrew Whigham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 30
总计 25,170
